Date/Time: Sat, 08 Feb 2025 19:10:27 +0000
Stop Loss fixed based on Amount in Currency
View Count: 745
[2020-07-21 10:43:36]
AD544 - Posts: 64
Is there a way to set up the stop loss based on fixed amount of money?
Let me explain:
I am long the MNQ with 3 contracts with a stop loss of 30 points for each contract, that's 180$
At a certain point I add 2 more contracts, so my total long position is based on 5 lots.
The problem is that if I add 2 more contracts the stop amount will rise to 300$ due to the fact that I am now with 5 contracts
I would like to have the possibility to fix the stop loss with the same amount that I had with 3 contracts that's 180$
So if I am long 5 lots the stop should rise from previous position at the amount of 180$
Is that possible?
Date Time Of Last Edit: 2020-07-21 10:46:10
[2020-07-21 19:57:45]
Your Sierra Chart account which you have logged into this Support Board with is expired. So we know what Sierra Chart account you are using, go to Help >> Support Board from within the Sierra Chart desktop program and then post in this thread telling us this is done.
[2020-07-21 20:18:32]
AD544 - Posts: 64
I have an account with AMP, but where is the problem?
You would tell me if my answer can be considered?
It's very important to know that for my trading strategy
Maybe I have not understand well... If I am an AMP customer with the free package, I can't post in this board?
Date Time Of Last Edit: 2020-07-21 20:21:24
[2020-07-21 20:32:43]
AD544 - Posts: 64
And by the way I have been a Sierra Chart user for many years (not exclusively) since 2008 with Transact Futures
[2020-07-22 10:10:46]
ForgivingComputers.com - Posts: 997
This can be programmed into a custom trailing stop with ACSIL. I sent you a direct message request.
Brad Houser
