Date/Time: Sat, 08 Feb 2025 17:42:15 +0000
HELP I CANNOT TRADE ERROR MESSAGES COMING UP LEFT AND RIGHT
View Count: 531
[2020-07-21 10:20:38]
User849502 - Posts: 353
I logged on this morning, and traded, all was fine. I came back and rebooted computer and logged on tried to open chartbook and it said it wasn't supported by current version and to upload new. I just did that 4 days ago, but hit the 'upload latest' and you will see the message that popped up. Restarted and tried another chartbook and it opened but I saw data was missing. And white box opened and you see all the error codes.
HELP I CANNOT TRADE
imageerrors.PNG / V - Attached On 2020-07-21 10:20:09 UTC - Size: 109.91 KB - 194 views
imagemore error.PNG / V - Attached On 2020-07-21 10:20:19 UTC - Size: 87.69 KB - 225 views
[2020-07-21 10:39:34]
In the screenshots we are partially able to see the error messages and what we see is error code 112 from the Windows operating system. This means that your storage drive is out of space.
Exit from Sierra Chart, and then go to this folder: C:\SierraChart\Data. Delete files older than 30 days that have a scid extension to free up disk space.
You should also delete other unnecessary files on your drive. What we recommend you do is to get a 500 GB dedicated solid-state drive just for Sierra Chart.
Date Time Of Last Edit: 2020-07-21 10:40:39
[2020-07-21 10:48:42]
ok thank you doing this right now and will also do what you say re disc drive
