Date/Time: Thu, 17 Sep 2026 01:07:06 +0000
MorningStar Spot Forex Data Feed Now Available
View Count: 3506
| [2020-07-21 05:59:18] |
Sierra Chart now provides the MorningStar spot Forex and spot metals real-time data feed through the Sierra Chart Exchange Data Feed: Sierra Chart Exchange Data Feed The fee for this in addition to the real-time data connection, is 21 USD per month. The symbols are listed under File >> Find Symbol >> MorningStar Forex. They are listed for the SC Data-All Services and LMAX services. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-07-23 10:53:01
| [2020-07-21 15:11:17] |
| ticinotrader - Posts: 429 |
Dear Support, Can you please confirm that this means *real-time data* for all the listed FX symbols under this category, starting with the sign '^' when being subscribed to MorningStar? Thank you. |
| [2020-07-21 18:52:11] |
Yes real-time data for those symbols. We have reduced the amount of listed symbols but there are considerably more. They cover foreign-exchange data really for any combination of currencies. We have only listed the more common currencies. If there any additional pairs you want in real-time, just let us know. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-07-22 08:53:00] |
This is *great*, I have just tried and it works perfectly. There is only one issue, when I open Daily/historical charts, there is an incorrect section of the chart that shows data far away from the current/normal price of the given symbol. http://www.sierrachart.com/image.php?Image=1595407510251.png I have checked and it is the same for all that I tried. Examples are ^EURHKD, ^CHFZAR, ^USDTRY etc. This happens with daily charts only, intraday charts are not affected. Can you please advise? |
| [2020-07-23 05:10:36] |
We do not observe this. Fully re-download the data in the chart: Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download". You just need to do this once per symbol and not for each chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-07-31 15:46:24] |
| Chris32 - Posts: 81 |
There is no way to access these symbols with Interactive Brokers service? Or is it simply that we need to set them up ourselves in the Symbol settings?
| [2020-07-31 19:26:17] |
We can make them available for Interactive Brokers. We will do that.
| [2020-07-31 19:41:24] |
This is now done. Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-08-06 07:45:59] |
| User92573 - Posts: 614 |
I think the user may be viewing Morningstar delayed data hence the difference between the live price and last price shown on the delayed Morningstar feed. Great addition for SC. |
| [2020-08-06 18:58:53] |
We do not offer a delayed feed for the MorningStar data. Only real-time.
| [2020-08-06 20:42:01] |
Interesting. So I have a GBPUSD 1 min (FXCM) chart displayed and a ^GBPUSD 1 min (Morningstar) chart currently displayed. Both are changing price even at this late hour. GBPUSD last bar is 21:39 ^GBPUSD last bar is 21:19 UTC 21:39 Which was the basis for my comment. Many thanks ... maybe you could answer my question re replay? |
| [2020-08-07 04:42:46] |
In regards to the MorningStar symbols the periodic updating you are seeing is explained here at step 15: Sierra Chart Historical Data Service: Setup Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-08-07 04:43:10
