Date/Time: Sat, 08 Feb 2025 18:07:12 +0000
Assigning Interactive Brokers Trading Account to Sierra Chart
View Count: 540
[2020-07-21 04:19:30] |
User169009 - Posts: 4 |
How do I assign my Interactive Brokers trading account to Sierra Chart in the Request Form when Interactive Brokers is not listed in the drop down menu of "Clearing Firm Name" ? Thanks! |
[2020-07-21 09:18:11] |
Interactive Brokers is not supported with the Sierra Chart Order Routing service which it looks like you are referring to. You will need to use a different clearing firm other than Interactive Brokers. The supported list is here: https://www.sierrachart.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php#SetupInstructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
