Date/Time: Sat, 08 Feb 2025 15:57:09 +0000
Gain Data Feed: Intraday Historical not downloading to chart
View Count: 675
[2020-07-20 13:45:18] |
User847587 - Posts: 18 |
Intraday historical data not downloading, displayed on chart under the Gain data feed. Currently limited to about 9 hours of data. Need assistance. |
[2020-07-20 17:35:50] |
You need to change to Sierra Chart Advanced Service Package 5 for extended historical data support for Gain Capital. Otherwise, the data comes from Gain Capital and that is limited. Just a few hours. Follow the instructions below: To change your Sierra Chart Service Package, select "Help >> Account Control Panel" on the Sierra Chart program menu. On the displayed webpage, click on the "Set Service Package for Renewal" link. Or go to this page: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation You will need to login if you are not currently logged in. In the "Available Services >> Choose Usage Time Service Package" frame, select the Service Package that you want to set your account to. Press the "Set" button. The remaining service usage time on your account will be adjusted based upon the cost of the package you are changing to. If the new package is a higher-priced package, then the usage time will be reduced due to the higher price. There is no charge for changing your Sierra Chart service package. Only your Sierra Chart account usage time ending date is adjusted. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
