Date/Time: Fri, 11 Sep 2026 12:06:17 +0000
Is the DTC Server possibly adding a large latency in the market depth updates
View Count: 872
[2020-07-20 08:12:35]
User442651 - Posts: 25
As soon as a message is received by the stream I stamp the time with the client's clock. This is compared with the timestamp in the MarketDepthUpdateLevelFloatWithMilliseconds message. I am finding that there is consistently a latency of about 350ms:
Message received at 2020-07-20 04:04:46.1515. Type: MarketDepthUpdateLevelFloatWithMilliseconds, Size: 29
Received market data for XBTUSD-BMEXT.
Timestamp: 2020-07-20 04:04:45.7880, Client Timestamp: 2020-07-20 04:04:46.1512, Latency: 00:00:00.3632265
Message received at 2020-07-20 04:04:46.1836. Type: MarketDepthUpdateLevelFloatWithMilliseconds, Size: 29
Timestamp: 2020-07-20 04:04:45.8310, Client Timestamp: 2020-07-20 04:04:46.1834, Latency: 00:00:00.3524565
However, the ping round-trip time to bitmex.com is about 95ms.
Is is possible that DTC server is creating a lag of about 300ms?
[2020-07-20 08:56:51]
Btw, I am certainly hoping this is a problem on my end, or else the DTC Server will not be of use to me.
My understanding was the DTC Server actually has sub-millisecond latency. Is this correct?
[2020-07-20 10:43:40]
The data is not coming directly from BitMex. So there is going to be an increased latency. But not as much as you are seeing.
