Date/Time: Mon, 25 Nov 2024 16:53:06 +0000
info
View Count: 1110
[2014-01-30 15:29:13]
User44790 - Posts: 21
Hi..could you help me..I have problem with data fromZMH4 daily and intraday...where is problem??
1.I dont have all data.
2.on Daily I have quote 4.1 and 1hour time frame I have 410,0...why??
3.same problem with download heating oil...my data finish 24.1. and they dont want to download another days..on 1 hour timeframe??
thank you Jaroslav
[2014-01-30 17:11:02]
1. Refer to these help topics:
http://www.sierrachart.com/index.php?l=doc/helpdetails6.html
http://www.sierrachart.com/index.php?l=doc/helpdetails7.html
2. This might not be necessary, but perform a Full Reset of the symbol settings as explained here:
http://www.sierrachart.com/index.php?l=doc/doc_GlobalSymbolSettings.php#FullResetSymbolSettingsSteps
After this reopen the Historical Daily chart.
3. Post an image of the chart, by following these steps:
https://www.sierrachart.com/index.php?l=PostingInformation.php#Image
[2014-02-24 13:35:57]
http://www.sierrachart.com/image.php?l=139324868718.png
this is screen from last day....
here is it problem N.2
http://www.sierrachart.com/image.php?l=1393248869263.png
this is screen from previous day...
thank you Jaroslav Hornak
[2014-02-24 13:40:59]
here is
attachmentZMK14.dly - Attached On 2014-02-24 13:38:41 UTC - Size: 26.35 KB - 540 views
[2014-02-24 18:22:25]
This is a problem with the Symbol settings.
Update them as explained here:
http://www.sierrachart.com/index.php?l=doc/doc_GlobalSymbolSettings.php#UpdateSettingsSteps
After this open new charts for the ZM symbol.
