Date/Time: Sat, 08 Feb 2025 15:49:28 +0000
Top Step Trading Rim Files
View Count: 668
[2020-07-19 22:24:03]
User547290 - Posts: 69
I have read the instructions for installing the Rim files in order to connect Sierra Chart to Rhythmic for connecting to Top Step, but the link that is provided to download the files gives a notice of "Access Denied" -
Here is the ZIP file that you can save which contains all the necessary files that you can extract to the C:\SierraChart\Rim folder:
https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=39787[/b]
Where is the files to download in order to run Rhythmic for top Step.
[2020-07-20 07:28:01]
Sierra_Chart Engineering - Posts: 18338
You can get the files from here:
Rithmic Bridge Files
Also be aware you need to direct Sierra Chart account :
Direct Sierra Chart Account
When you are using Sierra Chart that has been provided through an affiliate, you do not have a direct paid account with us, and you wish to access functionality that is not provided in your limited version, you must have an account with Sierra Chart directly and have a standard installation of Sierra Chart. To accomplish this, follow the instructions below:
