Date/Time: Sat, 08 Feb 2025 19:09:56 +0000
charts keep changing candles of the past while settings are the same
View Count: 608
[2020-07-19 15:08:19] |
User583771 - Posts: 6 |
I have a big issue, every some days my chart keeps changing candles from the past, for example: take the weeks of January 2020, 15 days ago they are looking in a way, today they are totally different... and I am sure I have kept the same settings since I have noticed this problem a lot of time. I use Day Session Only Weekly Chart Bars and followed this article to set it properly: Chart Session Times: Day Session Only Weekly Chart Bars How to solve? |
[2020-07-19 22:10:30] |
Is this a Continuous Futures Contract chart?
[2020-07-23 12:50:37] |
yes
[2020-07-23 19:58:54] |
First you are using Rithmic. We have discontinued support for Rithmic. Your service package provides no access to historical data from Sierra Chart services with Rithmic. So we cannot help with the data you are working with. Refer to: Regarding Rithmic (Our Final Post on this Subject) We will not be providing any further help with this is long as you are using Rithmic. For now use the Sierra Chart Historical Data Service in a separate installation: Sierra Chart Historical Data Service Also refer to: Continuous Futures Contract Charts: Understanding Back Adjusted Price Data and Comparisons Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
