Date/Time: Fri, 27 Nov 2026 23:07:58 +0000
[User Discussion] - Price Retracement Tool and Fibonacci Levels
View Count: 1496
[2020-07-18 17:10:26]
User680605 - Posts: 5
Can you add any text to the Fib Levels? For example say on the 50% level I want to add next to the 50% "Good Entry",
can this be done?
[2020-12-19 18:07:14]
User676363 - Posts: 90
Hello Support,
I am also wondering if this would be possible.
For example, to label levels with "Target 1", "Target 2", etc.
Makes it easier to combine with the RvR tool to and with bracket orders to get them setup properly and quickly.
Do any of the fibonacci tools in SierraChart support saving text along with the labels?
Or perhaps allow the user to create custom text such as Target 1 $price$ $ticks$ ?
The current system doesn't let me include price on just certain levels.
It's an all or nothing situation which makes it a bit busy...
What I would enjoy having is a way to type a description for each level and include variables to be replaced by SierraChart for the display exactly in the format I choose.
If not in SierraChart, does anybody know if a custom tool exists or perhaps just point me to the existing ACSIL code, if it's public, so that I can see about building something.
Thank you.
