Date/Time: Sat, 08 Feb 2025 18:47:03 +0000
Change all charts to use evening data
View Count: 582
[2020-07-18 03:54:02] |
User472677 - Posts: 362 |
How to change all charts to use evening period? I know his to do it one chart at a time. I have 60 charts in thdchart book. I would like to use a global setting to use evening period. |
[2020-07-18 05:13:23] |
You could link the Session Times across multiple charts and therefore when you change one of these related settings, they will all change among the linked charts: Working With Charts: Chart Linking That is the best you can do. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-07-22 02:53:51] |
It is a good idea. However this requires clicking every one of the 60 charts and making the change. Is there a better way so this can be accomplished quickly such as a global setting?
