Date/Time: Sat, 08 Feb 2025 16:54:58 +0000
Service Conn error
View Count: 577
[2020-07-17 23:26:31] |
user8888 - Posts: 159 |
I'm getting this (attached), out of the blue. Haven't done any changes at all. Thanks |
![]() Attachment Deleted. |
[2020-07-18 05:11:54] |
We have examined this issue and we see the scenario under which it occurs. This will be resolved in the next release. For now perform a Forced Login: Sierra Chart - Software Login Instructions: Forced Login Let us know if you can then connect to the external trading service. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-07-18 05:12:21
[2020-07-18 09:12:43] |
It worked. Without forcing the login. Thanks. |
