Date/Time: Mon, 25 Nov 2024 11:23:21 +0000
How to Change Foreground/ Text Color of Chart Trade Buttons
View Count: 1875
[2014-01-30 13:14:55]
User29698 - Posts: 28
Is this possible and if so, how? They are Black by default and I would like to change to white. Also, it would be good, if they used the same default font, that is defined in the Graphics Settings. I don't think they are currently do.
[2014-01-30 17:54:07]
The colors can be changed through Global Settings >> Graphics Settings. Refer to:
http://www.sierrachart.com/index.php?l=doc/doc_ChartTrading.html#CustomizingGraphics
[2014-02-04 19:18:03]
Well, it seems I can change pretty much any colour in sierrachart (which is grea), but I have still not found a way to change the foreground colour of the buy/ sell buttons on the chart trader. I am familiar with how to change the graphic seetings as per link provided by SC above, but again, there is no option to change the text colour of the chart trader buttons.
Can I suggest, that this is added in a future release.
Also, there seems to be a fault with the background colouring of the "Cancel All" button in the chart trader.
The button itself remnains grey, but the background of the text only changes to whatever background colour I select for the flatten and reverse buttons in the graphic settings. Again, it would be good if this could be fixed in a future release.
[2014-02-04 20:01:07]
In Global Settings >>Graphics Settings you need to change:
Chart Trade Window Buy/Sell Button Color
When there are no orders to cancel, the Cancel All button will be disabled and that is why it has the appearance that it does. This is operating system control. We cannot change this.
[2014-02-04 20:16:17]
Thanks, but this only changes the background of the button, NOT the thext. The text is black bt default and I have not seen an option anywhere to change this.
[2014-02-06 07:33:34]
OK got it. We had not recognized you meant the text. There is no way to change the text. We had not thought about that. We will look into that.
Date Time Of Last Edit: 2014-02-06 07:33:42
