Date/Time: Tue, 11 Feb 2025 09:02:15 +0000
The Chartbook file requires ...
View Count: 664
[2020-07-17 14:49:01]
mchoppla - Posts: 20
The Chartbook file requires a newer version of Sierra Chart or is not a valid Chartbook. File: C:\SierraChart\Data\Mein sierra.Cht | 2020-07-17 15:45:33.006 *
Hello sierrachart shows me the problem with some chartbooks. Was there any help given since I did? I thank you;)
[2020-07-17 19:30:03]
Did you update to a recent release and then go back to an older release, and now are getting this message? Refer to the first posting in this section for why we are asking this:
https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer2104
Otherwise, you can always use a Backup Chartbook. Refer to the information here:
Chartbooks (Workspaces): Accessing a Backup Chartbook File
[2020-09-03 16:36:38]
User84094 - Posts: 47
I have also same issue already twice.
I will make new chartbooks and hope that this issue don't reapeat.
2 hours ago worked but just now open SC got same message
" The Chartbook file reuires a newer version ... or is not valid Chartbook "
[2020-09-03 19:00:42]
We do not know why you would have this problem as long as you are not going back to an older version of Sierra Chart. But even in that case it would have to be a significantly older version.
Date Time Of Last Edit: 2020-09-03 19:00:53
