Date/Time: Sat, 08 Feb 2025 17:00:17 +0000
SC Data-All Services Activation Request
View Count: 545
[2020-07-16 22:41:42] |
Sheekh0128 - Posts: 1 |
Hello Sir, Can you please activate this trial for me. I need to test drive SC. Thx |
[2020-07-17 14:30:11] |
John - SC Support - Posts: 37842 |
Your account has been activated and the usage time extended if necessary. If Sierra Chart is running, it will automatically be activated within about three minutes. However, you may need to exit from the Sierra Chart charting and trading software by selecting "File >> Exit". And then open Sierra Chart through the icon on your desktop or through the desktop Start menu. After your Sierra Chart usage time ends you need to pay for additional usage time through "Help >> Add Usage Credit". For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
