Date/Time: Sun, 20 Sep 2026 01:09:06 +0000
Denali Data + Equties feed?
View Count: 943
[2020-07-16 21:52:45]
User559224 - Posts: 22
I currently have the SC denali data feed for futures through Amp. Is it possible to have this feed and a feed for equities run simultaneously and on the same account?
[2020-07-17 10:09:11]
User255336 - Posts: 28
Yes, this is how I am using Sierra Chart. You just need to add the additional exchanges that you want to activate. I have U.S. Equities (NYSE, NASDAQ, AMEX, BATS) activated. Keep in mind there is no market depth available.
https://www.sierrachart.com/UserControlPanel.php?page=ExchangeDataFeedFeatures#DataConnections
[2020-07-17 12:40:53]
I did further reading and I didn't think multiple real-time connections were possible. You just activated equities on the same account you use for Amp? Which service are you using?
I imagine if you use SC Futures Order Routing/Data[trading] that you'll only get futures, but if you use SC Data - All Services [data] you'll only get data and be unable to trade futures.
[2020-07-17 12:43:52]
I activated it in my control panel here, didn't involve AMP in any way. I use CQG for order routing for the moment.
[2020-07-19 07:47:20]
Yes this is fully supported. Just go through the step-by-step instructions here to use the Sierra Chart Exchange Data Feed:
https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#SetupInstructions
You just need to activate the Real-time Connection and the US Equities exchange.
Let us know if you need more help.
Date Time Of Last Edit: 2020-07-19 07:47:47
