Date/Time: Mon, 25 Nov 2024 09:59:15 +0000
cannot connect to Barchart
View Count: 1735
[2014-01-30 11:44:49]
User53496 - Posts: 34
hi, i have a new accout at Barchart, and cannot connect. here is the log:
Barchart: Verifying status of username. | 2014-01-30 06:43:49
Barchart: Requesting user settings from http://www.ddfplus.com for SCeyal | 2014-01-30 06:43:49
HTTP request #5 returned the following error: Windows error code 12029: A connection with the server could not be established | 2014-01-30 06:44:10
Barchart: Verification of username status failed. | 2014-01-30 06:44:10
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-01-30 06:44:10
To prevent further connection attempts, select 'File >> Disconnect'. | 2014-01-30 06:44:10
Barchart: Reset socket. | 2014-01-30 06:44:10
Barchart: Disconnected. | 2014-01-30 06:44:10
Will reconnect to the server in 5.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-01-30 06:44:10
Barchart: Verifying status of username. | 2014-01-30 06:44:15
Barchart: Requesting user settings from http://www.ddfplus.com for SCeyal | 2014-01-30 06:44:15
File >> Disconnect selected. | 2014-01-30 06:44:21
Barchart: Reset socket. | 2014-01-30 06:44:21
Barchart: Disconnected. | 2014-01-30 06:44:21
[2014-01-30 16:01:50]
sure i did.. it's not my first time :/
but i need to know what's the problem
[2014-01-30 16:05:32]
This is the relevant error:
Are you able to get to this webpage in your website browser?:
[2014-01-30 16:06:55]
yes
[2014-01-30 16:12:39]
Then this means a firewall is blocking the connection on your system.
Refer to help topic 1.2 here:
http://www.sierrachart.com/index.php?l=doc/helpdetails1.html#h1.2
Date Time Of Last Edit: 2014-01-30 16:15:10
[2014-01-30 16:14:44]
ok, i'll handle it.. thanks!
