Date/Time: Sat, 12 Sep 2026 11:05:02 +0000
[Programming Help] - Custom Study : Trigger event in all charts from Chartbook
View Count: 961
[2020-07-15 19:15:05]
User612903 - Posts: 51
I try to find a way to achieve this, but did'nt find it.
I'd like to trigger an event when I press a button or something, for ALL charts within a chartbook.
Currently I use a custom menu to trigger an event. But I need to do it chart by chart. I was wondering if I can save time and trigger the event chartbook by charbook ?
I was thinking maybe I can listen to a specific custom global setting or something, but did'nt find the way.
Thank you for any suggestion,
Regards,
[2021-07-29 02:21:17]
Showbiztrader - Posts: 8
You can link all the charts in a chartbook and trigger a study for all at the same time. There are several options you can link and you'll see them under the "Chart Linking" on right side of Advanced Settings 2, under the Chart Settings.
>>Chart Settings
>>Advanced Settings 2 tab
>>Chart Linking
>>set link number
>>set link type (ie: symbol, bar period, scroll position...etc...)
>>make sure ALL other charts, in the Chartbook, are set the same way (ex: Link #5, Bar period)
