Date/Time: Sat, 08 Feb 2025 15:37:57 +0000
[User Discussion] - Trading with IB using SierraChart Denali Datafeed
View Count: 518
[2020-07-15 18:25:18] |
User419671 - Posts: 5 |
Hello, I have this problem, I have InteractiveBrokers live account and I would like to trade according SierraChart Denali live data, because IB data they are not accurate, I need accurate tick data. I know, that I need two installation of SierraChart. First installation with IB datafeed and second installation with SierraChart datafeed. I should enter trades from first installation. But I don't know how to connect charts between first installation of Sierra and second installation of Sierra. I try to find an answer, but I was not successful. Can you help me with this? Thank you very much. Martin Jindracek |
[2020-07-15 19:33:39] |
I know, that I need two installation of SierraChart. First installation with IB datafeed and second installation with SierraChart datafeed. I should enter trades from first installation. But I don't know how to connect charts between first installation of Sierra and second installation of Sierra. I try to find an answer, but I was not successful. We do not know where you got this information from but it is definitely not correct.You need to follow the instructions here: Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
