Date/Time: Sat, 08 Feb 2025 15:32:28 +0000
Message in Popup Message Board
View Count: 553
[2020-07-15 17:39:33]
User579561 - Posts: 2
I keep seeing this message that says Client does not have this privilege...Not sure if I need to be doing something or if something is wrong
Error setting Date Time a required privilege is not held by the client
[2020-07-15 20:16:12]
It is not really anything to worry about. Refer to this setting which is trying to set your clock, but you do not have privileges to make the change:
General Settings Window: Periodically Set System Date-Time from Server (Global Settings >> General Settings >> General >> Update Intervals)
