Date/Time: Sat, 08 Feb 2025 15:30:46 +0000
Change color of a line based on Last being above or below it
View Count: 515
[2020-07-15 13:58:00] |
User772499 - Posts: 48 |
I don't see an option in auto-Coloring or Color options in studies. Is this possible to set up? Thanks! |
[2020-07-15 20:06:16] |
Refer to the following: Color Bar Based on Alert Condition Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
