Date/Time: Sat, 08 Feb 2025 15:30:15 +0000
Key to connect Topstep Trader
View Count: 700
[2020-07-15 01:27:29] |
User672918 - Posts: 2 |
Hello I trade Topstep trader and according to them I'm suppose To request a Key from Sierra to continue my setup, thank you
[2020-07-15 18:55:45] |
There is no key required. Sierra Chart does not support Topstep trader since they use Rithmic. Refer to: Regarding Rithmic (Our Final Post on this Subject) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
