Date/Time: Sat, 08 Feb 2025 13:57:46 +0000
TICK-NYSE is updating slowly
View Count: 573
[2020-07-14 18:39:18] |
User816220 - Posts: 80 |
TICK-NYSE is updating slowly since the sharp move today at ~13:58:30ET. Here's a 1 second chart showing the drop in the update rate. http://www.sierrachart.com/image.php?Image=1594751859549.png |
[2020-07-14 18:47:30] |
We are looking into this. There would have to be some problem with the source data feed we get from Barchart.
[2020-07-14 18:49:10] |
Yes confirmed. The Barchart US equities feed has a problem. We are contacting them.
