Date/Time: Sat, 08 Feb 2025 13:52:59 +0000
Stops being cancelled
View Count: 514
[2020-07-14 18:01:33] |
User480347 - Posts: 13 |
My stops keep getting cancelled if my margin is to low and I have to manually close them. "Trade Order Error - CQG order update. Status: REJECTED. Text: No margin available after satisfying existing position margin (if any)..." What can I do to fix this? Thanks |
[2020-07-14 20:30:43] |
Contact your broker about this.
