Date/Time: Sat, 08 Feb 2025 15:28:03 +0000
Subscribed to both Denali(futures) & Sierra Exchange data
View Count: 494
[2020-07-14 16:26:40] |
ejtrader - Posts: 688 |
For Denali - I understand 2 connections are allowed. For Sierra Exchange feed - how many connections are allowed? With 2 Denali feed - I can have 2 seperate instances on one machine. Would I be able to run 2 Sierra Exchange instances(seperate from denali instances) on the same computer? thanks |
[2020-07-15 05:12:30] |
For Sierra Exchange feed - how many connections are allowed? 1 connection. Would I be able to run 2 Sierra Exchange instances(seperate from denali instances) on the same computer? Using the method here:https://www.sierrachart.com/index.php?page=doc/MultipleServices.html#AccessingMarketDataFromOtherInstancesOfSierra%20Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-07-15 05:13:09
