Date/Time: Sat, 08 Feb 2025 18:00:08 +0000
HLC Bars as Range indicator
View Count: 1199
[2020-07-14 14:05:40] |
User454021 - Posts: 5 |
Hello, is it possible to construct HLC Bars set up as range indicators in chart region 2? Please have a look at the attached screenshot. Thank you. |
[2020-07-15 11:26:04] |
Refer to these two pages: Using the Basic Arithmetic Studies Study Overlay - OHLC (Open, High, Low, Close) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-07-15 11:26:31
[2020-07-20 05:25:42] |
I tried all variations with Study Overlay OHLC, but this way it's not possible
[2020-07-20 18:10:57] |
Sawtooth - Posts: 4173 |
You can do this with the Spreadsheet Formula (Bar) study. Put the attached Study Collection in your Sierra Chart \Data folder, then go to Analysis >> Day Range+ The study collection will load the Spreadsheet Formula (Bar) study with the correct formulas and settings. |
[2020-07-21 13:05:18] |
This works perfectly. Thank you so much!
