Date/Time: Sat, 08 Feb 2025 17:16:38 +0000
how to FLATTEN a PORTION of total position
View Count: 1007
[2020-07-14 11:51:33]
User525733 - Posts: 126
is there a way to FLATTEN a portion of the total position using a hotkey?
e.g: i am long ( or short ) 4 contacts....the desired hotkey should close ( say 50% ) of the position when pressed.
yes i am aware that i can manually enter a mkt sell/buy order to flatter a portion of the total position...trust me, it is error prone as i have accidentally ADDED to the position instead of reducing it.
thanks
[2020-07-15 19:14:21]
Your Sierra Chart account which you have logged into this Support Board with is expired. So we know what Sierra Chart account you are using, go to Help >> Support Board from within the Sierra Chart desktop program and then post in this thread telling us this is done.
[2020-07-17 19:26:18]
You can certainly set up keyboard shortcuts to change the order quantity. Refer to:
Basic Trading and the Trade Window: Control Bar Buttons for Preset Order Quantities
And you can set up a keyboard shortcut for a market order:
Basic Trading and the Trade Window: Trading Keyboard Shortcuts
