Date/Time: Fri, 28 Feb 2025 13:50:16 +0000
Chartbooks cannot be opened although Enabled in General Settings
View Count: 1086
[2020-07-14 06:21:49]
User437588 - Posts: 69
I closed Sierra Chart after trading as usual. It is activated to open several Chartbooks.
Now only 1 Chartbook is opened at each restart although the others are still activated. What can be the reason for this?
Private File
[2020-07-14 08:02:43]
Make sure those Chartbooks actually exist. And also check the relevant settings here:
General Settings Window: Select Files to Open On Startup (Global Settings >> General Settings >> General >> Startup)
Date Time Of Last Edit: 2020-07-14 08:03:10
[2020-07-15 06:36:36]
I have checked everything but I cannot find the mistake.
Where should the Chartbooks be?
It surprises me that the Chartbooks can be opened by Manuel via File 1- 10.
As soon as the Chartbooks are opened and I have worked with them and saved everything, the date of 13.07.20 10:43 is still there.
How can that be?
Private File
[2020-07-15 08:10:22]
It seems like perhaps the Chartbook files are being saved to a different folder than the default.
Are you using Chartbook Groups at all?
Date Time Of Last Edit: 2020-07-15 08:10:43
[2020-07-15 08:47:48]
How can that be I haven't changed anything?
No, not yet.
[2020-07-20 18:28:50]
Just verify where the chartbooks are actually being saved to.
Close all of your Chartbooks and open one Chartbook through File >> Open Chartbook. Save it and then check the modified date. It should be current.
Date Time Of Last Edit: 2020-07-20 18:29:01
[2021-08-26 09:55:37]
Hello
Thank you very much. I have uploaded all the data according to your instruction. The historical data is now displayed again every time I start the program.
Thank you
