Date/Time: Sat, 08 Feb 2025 13:59:08 +0000
E6 Futures is missing (CME)
View Count: 1050
[2020-07-13 20:01:56] |
User783093 - Posts: 27 |
Hello. For some reason can't find 6E Futures in CME Futures list, only M6E and E7 is available. https://www.cmegroup.com/trading/fx/g10/euro-fx_contract_specifications.html I've found them in a documented symbol list on Sierra site with misspelled name E6 (correct one is 6E), but still can't add it to charts. It's the most liquid FX futures contract, it should be in this list. Thank you in advance |
[2020-07-14 08:19:06] |
In the case of Interactive Brokers the symbol begins with EUR and it is listed in File >> Find Symbol >> Futures-CME.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-07-14 08:19:38
