Date/Time: Sat, 08 Feb 2025 13:48:14 +0000
Number Bar Study Displaying Incorrect Volumes
View Count: 726
[2020-07-13 17:54:02] |
User290454 - Posts: 6 |
I use "Volume per Bar" as the bar period type, set at 200. Hence each number bar should display a bar with bid and ask volumes totaling 200. My data feed is Denali. Below is a screenshot where the total for the number bar equals 107, but the chart values shows a total volume = 200, with ask = 103 and bid V = 97 for delta = 6. The number bar is not consistent with the actual volume. This bar is from today at 12:06:40 EST http://www.sierrachart.com/image.php?Image=1594662108666.png Below is another screenshot where the total for the number bar equals 58, but the chart values shows a total volume = 200, with ask = 168 and bid V = 32 for delta = 136. This bar is from today at 12:23:09 EST http://www.sierrachart.com/image.php?Image=1594662676555.png Would appreciate any support to investigate and resolve this issue. Best regards |
[2020-07-13 18:03:23] |
User907968 - Posts: 826 |
Make the columns wider, you are truncating the numbers within the number bars when the bid/ask volume at price has more than 2 digits.
[2020-07-13 20:15:14] |
Let us know if the issue is what is said in post #2. That would be the only explanation.
[2020-07-13 20:23:05] |
Yes, issue resolved. Thank-you
