Date/Time: Sat, 08 Feb 2025 13:51:05 +0000
[Order Type] Opening/Closing Trades Snippet in Sierra Email
View Count: 514
[2020-07-13 17:39:05] |
MichaelPPTF - Posts: 69 |
Hello Support, I see that in trade log SC can distinguish between opening and closing trades. However in SC email notification I see nowhere to put in a snippet to tell me whether a trade was opened, or closed (sometimes I go reverse at certain levels). Is this something can be done on my end that I don't know, or is it a SC system level implementation? Would you consider adding this snippet to make the email notification better suited for those who not sitting in front of their trading systems all day? Thanks! |
[2020-07-14 08:20:14] |
We will see if we can add that field of information but it may not always be accurate.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-07-14 08:20:40
