Date/Time: Sat, 08 Feb 2025 14:00:06 +0000
Chartbooks are no longer opened!
View Count: 495
[2020-07-13 16:37:42] |
User941471 - Posts: 6 |
I closed Sierra Chart after trading as usual. It is activated to open several Chartbooks. Now only 1 Chartbook is opened at each restart although the others are still activated. What can be the reason for this? |
[2020-07-13 18:44:52] |
We need you to post on the Support Board with your active Sierra Chart account. To do that select "Help >> Support Board " from within Sierra Chart. If you did not get an answer to your prior question, post here again after doing the above confirming that you have logged in with your current account to let us know. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
