Date/Time: Sat, 08 Feb 2025 14:18:53 +0000
TD Ameritrade - SC Version 2025 - Ameritrade Not enabled
View Count: 742
[2020-07-13 16:36:53] |
ejtrader - Posts: 688 |
Hello SC Team - I am unable to connect to Ameritrade any longer and SC is forcing an update. With the current version I get this message - package not enabled. Could you please help. I understand that Ameritrade is no longer supported - but the problem here is SC is forcing an update and ameritrade connection is NOT enabled with older version any longer. thanks |
[2020-07-13 18:44:19] |
We are not supporting Ameritrade in any way. We are declining this request completely. Please do not ask us about Ameritrade further.
