Date/Time: Sat, 08 Feb 2025 14:19:37 +0000
real time data for s&p futures
View Count: 1161
[2020-07-13 16:23:04] |
User757925 - Posts: 2 |
Hi I would like to get real time s&p futures info on my sierra charts. I activated a couple of services to get this data, but do not still see the real time. Can you please help me with this? Thanks, Harsha |
[2020-07-13 22:42:57] |
Can someone help me with this?
[2020-07-14 04:09:45] |
User71961 - Posts: 144 |
1) what broker did you connect to sierra chart? (you must disconnect and then reconnect 1st day of the month so SC knows you have an active futures account at a supported broker) 2) are you paying for the SC Data feed? 3) if yes to #2, which exchanges data package did you choose? |
[2020-07-14 08:23:57] |
We assume you mean the E-mini S&P 500 Futures offered by the CME Group. The reason you are not getting real-time data from the CME Group of exchanges is that you activated the Non-Professional exchange fees, but you have not verified that you have a live, funded, futures trading account, which the CME needs in order to allow you data at the lower priced fees. Refer to the following for instructions on how to connect once a month to your *live funded* trading account to qualify for the lower-priced exchange fees: Real-Time Exchange Data Feeds Available From Sierra Chart: Connecting Only Once a Month to Trading Account to Support CME Group Exchange Fees If you do not have a funded trading account or one with a supported trading service, then refer to this solution: Easy Solution to CME Funded Trading Account Requirement We recommend using the above solution in any case to avoid this problem in the future. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
