Date/Time: Sat, 08 Feb 2025 13:46:20 +0000
[User Discussion] - when to use [sc.Index]
View Count: 1415
[2020-07-13 14:14:19]
User681150 - Posts: 62
i am learning the ACSIL language and am trying to understand the why & when to use certain parameters
i have this simple function:
this FAILS
SCFloatArray opens = sc.BaseData[SC_OPEN];
SCFloatArray lasts = sc.BaseData[SC_LAST];
sc.Subgraph[0] = opens - lasts;
BUT this works... why do i need to add [sc.Index] to the last line for it to work, but dont need it on first 2 lines?? or why do i need it at all if AutoLoop is set to 1? thanks for an explanation
sc.Subgraph[0][sc.Index] = opens[sc.Index] - lasts[sc.Index];
[2020-07-13 17:53:58]
JohnR - User831573 - Posts: 309
In the first 2 lines, you are working with/defining the entire array - opens and lasts. To get at a specific bar, is when you use the [sc.Index].
assuming sc.Index = current bar
Line 3 says, for the subgraph[0] current bar, plot/output the calculated value of the current bar open - low.
Hope that helps,
JohnR
[2020-07-14 07:13:47]
User907968 - Posts: 826
As above, whether autoloop or not, you must pass an index parameter to access an array at a particular index.
This page contains relevant information -
Working with ACSIL Arrays and Understanding Looping: Introduction
The differences between manual and automatic looping are explained in the following articles:
https://www.sierrachart.com/index.php?page=doc/ACS_ArraysAndLooping.html#
Working with ACSIL Arrays and Understanding Looping: Manual Looping/Iterating
