Date/Time: Sat, 08 Feb 2025 13:38:24 +0000
Daily TPO Chart with 360 days composite profile - don't shows more then about ~40-45 days
View Count: 923
[2020-07-13 07:18:30] |
Stephan_CH - Posts: 18 |
Hi I have added to my tpo chart a composite profile. All seems fine so far, but I seems, that in any case only around 45 days are loaded anyway, in spite of I have set to load 360 days in Chart Settings. (i can see, if I play around with amount of days of "One Period at End of Fixed Time Length" in composite profile, that around 40-45 days the profiles shape seems then unchanged) In Global Settings I have set Data/Trade Service Settings "Intraday Data Storage Time Unit"=1Tick and "Max.Historical Intraday Days to download"=360 (for both, tick and non-tick data). My intention was first to have a 30-day TPO chart with a 360days composite profile on the right side. But it doesn't matter, if the chart is anyway a 360 TPO chart with composite profile. What could be the reason, that nothing happens whether I type in 40 days or 360 days - makes no difference in shape of the composite profile. What can be the reason for that? I would very appreciate it if you could give me a hint to solve this problem. Thanks a lot. Kind regards, Stephan PS: I have read a lot of support board posts and sierrachart helps for hours. |
[2020-07-14 08:29:15] |
Refer to the information here: Continuous Futures Contract Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
