Date/Time: Sat, 08 Feb 2025 13:46:18 +0000
MES Chart Time Starts At 15 Min Mark
View Count: 859
[2020-07-12 17:37:24] |
User169009 - Posts: 4 |
Hi Why does my MES 30 min chart not finish the candle that starts at EST 8:00 am but instead puts in a 15 min candle and then starts the subsequent 30 min candles at the 15 min mark? This continues until EST 1:15 am which it then puts in a 15 min candle and starts the subsequent 30 min candles at EST 1:30 am. This process repeats at EST 8:00 am (screen shot attached). This doesn't happen with my MNQ chart. Thanks. http://www.sierrachart.com/image.php?Image=1594575233406.png |
[2020-07-12 19:41:00] |
User255336 - Posts: 28 |
Check your chart settings and your session start / end times.
[2020-07-12 23:05:20] |
Refer to: Chart Session Times: Bar Starting Times Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
