Date/Time: Sat, 08 Feb 2025 16:49:51 +0000
Volume Profile Issue
View Count: 831
[2020-07-11 00:54:22]
Ed C. - Posts: 117
I am trying to set up a volume profile to display for the duration of the Globex session, and also extend VAH/VAL/VPOC until the next Globex session, but I can't seem to get more than a day's session to be displayed. I set the start time and end time correctly, but when I try to change the start date and end date to 0 (so it will show the selected start time and end time correctly), it locks up Sierra Charts. I've been trying for 3 days to get this right, and nothing seems to work.
How can one set up volume profile to show a selected time range for all days on the chart?
[2020-07-14 08:31:29]
You definitely do not want to use any of the Start or End times or dates within the Volume by Price Input settings.
You will want to use this particular Volume Graph Period Type:
Volume By Price Study: Multiple Profiles Based on Fixed Time
which relies upon the Chart Settings.
[2020-07-14 19:10:55]
Ed C. - Posts: 117
Is there any way to specify a volume profile that is for a set time every day that does not rely on the chart settings? For example, drawing a volume profile for the time period of 3 AM to 7 AM every day?
Thanks!
[2020-07-16 21:09:24]
Yes. Refer to the example here:
Volume By Price Study: 1 Day Volume Profiles Across Entire Chart Based on Session Times Different than Chart
