Date/Time: Sat, 08 Feb 2025 14:04:16 +0000
How to Not Overlap the Numbers on ZigZag Study?
View Count: 780
[2020-07-10 23:24:48] |
User628616 - Posts: 132 |
In the attached pic, I have ZigZag study twice: #1 ZZ is to display the AskBid Volume Difference, #2 ZZ is to display the Total Volume & Length of Wave. Now under the Bright Bold Number/Letters(L:29.50 V:12214) for example is the AskBid Volume Difference number, how do I adjust the position of #1 ZZ or #2 ZZ so that they aren't blocking one another but instead #2 ZZ on Top & #1 ZZ on Bottom
[2020-07-14 00:34:07] |
Just use the Text Label Offset Specified As and the Text Label Offset options for the Zig Zag studies: Zig Zag: Text Label Offset Specified As Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
