Date/Time: Sat, 08 Feb 2025 14:20:01 +0000
Line Tool Config Ext property doesn't save
View Count: 669
[2020-07-10 15:30:00]
ZenAlchemist - Posts: 23
The ext property of the line doesn't save in the tool config.
imageLine Config Ext does not save.png / V - Attached On 2020-07-10 15:29:26 UTC - Size: 4.93 KB - 237 views
[2020-07-11 05:53:15]
The Ext option does not save with the Tool Configuration, as enabling that options changes the drawing from a Line to a Ray (or a Ray to an Extended Line). Refer to the information on the Ext setting here:
Chart Drawing Tools: Line | Ray | Extended Line Configuration
[2020-07-12 01:04:09]
My issue with this is that I cannot CTRL + drag a ray to make a copy of it (while keeping the slope intact). I would use a ray if I could do the drag/copy trick with it like I can a line. Can you review the drag/copy functionality of a ray?
Actually, never mind this. I see that it does work if I am careful not to click near the anchor points. My mistake.
Date Time Of Last Edit: 2020-07-12 01:07:07
[2020-07-12 01:09:57]
Or rather, it seems I need to select the ray and drag beyond the half way point between the anchors, then it works.
