Date/Time: Sat, 08 Feb 2025 12:10:52 +0000
OpenGL GPU Memory Issue - Crash
View Count: 651
[2020-07-10 00:10:57] |
User353585 - Posts: 66 |
When I Use OpenGL with the chart windows maximized, the GPU memory usage(monitored via Task Manager) cumulatively increases as I switch between the charts. then the platform eventually crashes after it reaches 100%. If I leave the charts native(not maximized), then the usage remains the same as I switch the focus between the charts. But the same sort of the problem persists because the memory usage is not released even after I closed the chartbook. My new laptop has 8GB of system memory and Intel UHD internal graphics. It happens with fresh installations of both Windows & Sierrachart. I tested with a new chartbook without any indicator. Can you please check this issue? I don't want to go back to the software rendering because OpenGL is much faster when I have many custom indicators on the chart. Date Time Of Last Edit: 2020-07-10 00:15:44
[2020-07-10 01:35:43] |
We will look into this.
