Date/Time: Mon, 25 Nov 2024 08:50:14 +0000
3 copies on different systems
View Count: 1107
[2014-01-29 11:57:28]
milenmitzik - Posts: 27
How to use 3 copies on different systems concurrently.
And is it possible to start more then 2 copies on 1 computer
[2014-01-29 15:39:52]
Sierra Chart - Max - Posts: 5730
To use Sierra Chart concurrently on 3 computers, you will need Sierra Chart package 5.
You can run more than 2 copies on 1 computer.
Sierra Chart Support
[2014-01-29 17:00:19]
To change your Sierra Chart service package, select "Help >> Account Control Panel" on the Sierra Chart program menu. On the displayed webpage, click on "Change Service Package".
The remaining service usage time on your account will be adjusted based upon the cost of the package you are changing to. If the new package is a higher-priced package, then the usage time will be reduced due to the higher price.
There is no charge for changing your Sierra Chart service package. Only your usage time is adjusted.
