Date/Time: Sat, 08 Feb 2025 12:33:11 +0000
Change the Box Color of the 'Current Price' on top of the chart
View Count: 884
[2020-07-09 15:26:05] |
User181601 - Posts: 25 |
Tried a few things but didnt get the right term and I'm still stuck ... I referred to another message and also couldn't get it_ How to change CURRENT PRICE value background color on Top and R side of chart I need Change the Box Color of the Current Price which is now in black and not properly visible Thank you for help |
[2020-07-09 20:28:15] |
You cannot change the color of that box in the header line. It is automatically selected to be the reverse of the color of the Chart Text color. You can remove that background if you like, refer to the information here: Working With Charts: Chart Header Text Colors You can only independently control the color of the Last Trade Price box in the values scale. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-07-09 20:28:34
[2020-07-09 21:27:33] |
thank you engineer for your kind support and clear explanation
