Date/Time: Mon, 25 Nov 2024 12:53:24 +0000
Custom Dll compiled with Visual Studio not running on the other users' machines
View Count: 2789
[2014-01-29 11:32:14] |
Viacheslav Malafeev - Posts: 88 |
Hi All, I'm writing my ACSIL studies in Visual Studio 2012 and they work perfectly fine on my computer. But as soon as I send a dll to someone else, they can't open it - http://screencast.com/t/uqMa2wZI1R3s, and I have to recompile it using the built-in compiler. What could be the problem? Many thanks, Slava. |
[2014-01-29 11:48:00] |
ganz - Posts: 1048 |
Viacheslav Malafeev SCDLLName("...") присутствует в коде? Date Time Of Last Edit: 2014-01-29 11:48:17
[2014-01-29 11:50:16] |
да
[2014-01-29 15:43:16] |
Sierra Chart - Max - Posts: 5730 |
To use Visual C++, refer to the instructions here: http://www.sierrachart.com/index.php?l=doc/doc_VCExpress.php Sierra Chart Support Date Time Of Last Edit: 2014-01-29 16:21:14
[2014-01-29 16:23:35] |
Most likely this is the result of Sierra Chart not being able to open the DLL file. Sometimes when transferring a DLL file from one computer to another, the file gets locked. And it needs to be unlocked. On the destination computer right-click on the DLL file and select Properties. There should be an option allowing the file to be unlocked or allowed. Something like that.
[2014-01-29 17:50:05] |
If it's because file is locked then why do the dlls that have been compiled in the built-in compiler work fine on a destination machine, while the ones compiled in the VS 2012 are not recognized properly?
[2014-01-29 17:59:36] |
What i have to do every time i finish coding is COPY the code from my VS project to an external editor and then compile it by SC which means that the CODE itself is fine
[2014-01-29 18:00:48] |
This we do not know. We cannot say for sure what the problem is. Could you send us the DLL file compiled with Visual C++ to support AT Sierra Chart.com. Or you can privately attach it here. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-01-29 21:12:03] |
This is the file
Private File |
[2014-01-30 11:17:09] |
Graham - Posts: 44 |
The machine you're trying to run the file on is not running SC on Wine or Crossover or some other platform? I had exactly the same issue building a DLL within VS and tested on SC running Windows 7. As soon as I copied the file to the SC installation on my Mac (running crossover) I had to recompile using the built in compiler. |
[2014-01-30 15:37:21] |
It's Windows 7/8.
[2014-01-30 16:57:30] |
When we try to use this DLL file by going to Analysis >> Studies >> Add Custom Study, this is what we receive in the Message Log: Error loading \Max CrossMarket.dll. Windows error code 126: The specified module could not be found. We really are not sure why this would happen and this is going to be something caused by the Windows operating system or Visual C++. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-01-30 17:42:03] |
Ok how about this one?
Private File |
[2014-01-30 18:08:59] |
We do get the same error message: Error loading \Ehlers.dll. Windows error code 126: The specified module could not be found. We really have no idea why this happens. You really would have to consult with Microsoft about it. Have you tried using Visual C++ 2010? This is what we use. There is no chance we would ever use a newer version. We really have given up on the junk from Microsoft and plan to be moving away from their development tools. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-01-30 18:09:26
[2014-01-30 23:58:36] |
onnb - Posts: 662 |
It might be a dependency issue. You can try seeing if this is the case using http://www.dependencywalker.com/
[2014-01-31 00:34:37] |
Yes, this could be true. But we would think the error message would be different. This actually probably is indeed the problem. You probably need to install the visual C++ 2012 redistributable package on the machines the DLL is used on. Or statically link the standard C++ Library into the DLL. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-02-01 08:23:30] |
How do i statically limk a library?
[2014-02-01 16:36:46] |
While the project is open in Visual C++, select Project >> [Project name] Properties. At the top of that window select Configuration >> All Configurations. Select Configuration Properties >> C/C++ >> Code Generation >> Runtime Library >> Multithreaded. This will select the non-debug multithreaded static library for all of the projects including the debug project. If you want to use the debug version of the multithreaded library for the debug build, do not select All Configurations at the first step and then you need to configure the library for each project configuration. We are just trying to make this easy by avoiding these steps. Also make sure you are not using MFC or anything like that in the project. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-02-02 18:58:09
[2014-02-02 14:27:44] |
No Runtime Library Sub Menu in C/C++ menu - http://screencast.com/t/KkPLsFaOrm7
[2014-02-02 18:57:43] |
It is under the Code Generation list. We see how we got confused by that with the way that that list works. When we selected Code Generation and then selected C/C++ later on, it still showed the same content.
[2014-02-07 21:44:07] |
Which one shall I choose out of these? http://screencast.com/t/VidH6zMtIx2T Thanks |
[2014-02-07 21:51:24] |
Multithreaded /MT.
