Date/Time: Sat, 08 Feb 2025 10:57:56 +0000
Denali data delay
View Count: 580
[2020-07-09 13:57:11]
User411173 - Posts: 2
Hi, I just got setup on Denali data but am experiencing a 20+ minute delay. I use Tradovate as a broker but don't plan on routing any orders through SC. Any help in resolving this would be appreciated. Thank you
[2020-07-09 14:51:46]
SC Support - Posts: 1930
Please login to your Tradovate Account so that we can verify its existence and therefore guarantee you the discounted Non-Professional CME Exchange fees, should you otherwise qualify for them:
[2020-07-09 18:35:18]
The reason you are not getting real-time data from the CME Group of exchanges is that you activated the Non-Professional exchange fees, but you have not verified that you have a live, funded, futures trading account, which the CME needs in order to allow you data at the lower priced fees.
Refer to the following for instructions on how to connect once a month to your *live funded* trading account to qualify for the lower-priced exchange fees:
If you do not have a funded trading account or one with a supported trading service, then refer to this solution:
Easy Solution to CME Funded Trading Account Requirement
We recommend using the above solution in any case to avoid this problem in the future.
