Date/Time: Sat, 08 Feb 2025 12:16:15 +0000
Color of wick opposite
View Count: 618
[2020-07-09 12:46:57] |
vish100 - Posts: 111 |
Hi, I have noticed a strange situation in my main price graphs. Some bars esp. with small body have an opposite WICK color to the main bar body (see screenshot) So for example the bar is a DOWN bar (with red color) but WICK is of green color and vice versa. I have checked graphic settings and the BAR HIGH-LOW UP and BAR HIGH-LOW DOWN colors are set to be same as that of the BAR BODY color. Then why this anamoly? Is this a bug? thanks |
[2020-07-09 19:50:54] |
You need to enable this setting: Graphics Settings: Color Candlestick High-Low Using the Outline Colors (Global Settings >> Graphics Settings >> Other) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-07-10 00:08:05] |
Yes I figured there is a setting and I will do that. But it should have still worked fine since I got the right colors in BAR HIGH-LOW UP and BAR HIGH-LOW DOWN colors setting. Isn't it? Thanks |
