Date/Time: Sat, 08 Feb 2025 11:23:47 +0000
Y Axis Commas
View Count: 583
[2020-07-09 10:49:28] |
User847587 - Posts: 18 |
Problem: Y axis numbers are too large. Example: Nasdaq 10697.50 Question: How do I change to read 10,197.50? Question2: Can the software round to the next integer? Like 10,698, using the example above? |
[2020-07-09 19:48:58] |
- No, you cannot change the format of the prices to include a comma. - You can set the price scale to format as you like. Refer to this setting: Chart Settings: Price Display Format (Chart >> Chart Settings >> Symbol >> Symbol Settings menu) Just be aware that the underlying data is still going to be drawn according to its tick size, so you may end up with multiple of the same value in the price scale. Also, to change the font size, refer to: https://www.sierrachart.com/index.php?page=doc/GraphicsSettings.html#Fonts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-07-09 19:49:53
