Date/Time: Sat, 08 Feb 2025 14:18:38 +0000
Replay V2033
View Count: 557
[2020-07-09 08:59:22] |
User92573 - Posts: 541 |
Dear Support I am finding an issue as I go back to using replay and the Jump method. If a single chart is selected all seems fine as long as you ignore the current bar (in all cases) which I expect is something to do with the way data is handled and not an issue. However when I select all charts (the test is using just 2 timeframes same symbol) I seem only able to jump 'back' - to next bar and not forwards. I can jump forwards - By time (units) and everything works perfectly and as expected even with a 24 chart, chartbook. Jumping back - By time (units) can be a little more demanding but I assume this is due to the way calculations are completed? I point this out not as it currently restricts me but as it does not seem to function as expected and might have been missed in a recent upgrade. Many thanks Date Time Of Last Edit: 2020-07-09 09:00:50
[2020-07-14 08:15:09] |
Nothing has changed with replay functionality in this regard.
[2020-07-14 09:01:29] |
That was me being tactful. Its the Next Bar option that is not working as expected and its use results in various unexpected outcomes when used within a chart group. This includes the smaller timeframes clearing all data save for 1 Bar. Please try the functionality for yourself. Many thanks Date Time Of Last Edit: 2020-07-14 09:04:55
