Date/Time: Mon, 25 Nov 2024 08:22:49 +0000
[User Discussion] - An Indictor That Will Count Back a Certain Number of Bars?
View Count: 1942
[2014-01-29 08:31:25] |
User25633 - Posts: 10 |
Not sure if this is possible but thought I would ask. Does Sierra Chart has an indicator or a way to count back a certain number of bars on the chart. For example, I am at the current bar and I want to see what the bar looked like 30 bars back, is there a way this can be done without having to count the bars myself? Thank you.
Date Time Of Last Edit: 2014-01-29 08:32:07
[2014-01-29 12:17:42] |
CT - Posts: 4 |
hi, i'm new to SC and ACSIL but i took the change to learn and created my first DLL that should solve your problem. Copy the attached file into your SC data folder add study, add custom study and choose countback change the countback number in study settings (default is 30) it places a market on the bar regards |
CountBack.dll - Attached On 2014-01-29 12:14:50 UTC - Size: 12 KB - 548 views |
[2014-01-29 17:55:26] |
To use the attached study DLL file, follow the instructions here: http://www.sierrachart.com/index.php?l=doc/doc_DLLUsage.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
