Date/Time: Sat, 08 Feb 2025 10:40:39 +0000
Sierra Chart can't finalize the opening process
View Count: 513
[2020-07-08 16:19:06] |
User981017 - Posts: 1 |
Hello, My Sierra chart has freezen when I was in position in real. Thanks to bookmap I closed everything several minutes later. Now Sierra Chart can't finalize the opening process correctly. It's always freezing. Thank's for your quick back answer. Best regards |
[2020-07-08 18:56:15] |
Refer to: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.16 - What to do if Sierra Chart is in a frozen state for an extended time due to extended high CPU usage caused by an automatically or manually opened Chartbook Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
